Xperia tx android 4.3 battery performance
yuanshen99
My phone left 60% at 6pm and it totally no battery and turn off at 7.30pm ,what the battery life in android 4.3,i didn't play any game and apss during the time ,most of the time the phone are in standby mode ,i feel that the battery life is not as good as android 4.1 ,what are sony doing?anyone can help to solve this problem?
6 REPLIES 6
Alexander1
I suggest that you check what have drained battery under settings > power management > battery.
Please also check the following topic:
http://talk.sonymobile.com/t5/FAQ/Battery-time-and-enhancement-features/m-p/347874#U347874
faisal3dfx
Bro I have the same problem. Check this thing and let us know if this happens to you too.
Charge your mobile to 100% then use your mobile data (just chat on whatssapp or something like this). When your battery level comes to 65% or less then 70% restart your phone. Now your battery should drop on to 40%-30% or even less.
If this happens please post your comment here. So that I could know that I am not the only person having this problem.
Thank you.
Alexander1
faisal3dfx
This trick dose not work. I've tried all even reinstalled my os using PCC and sus didn't work at all.
Alexander1
Well in that case you may want to have you your phone examined by a service center. Please contact your local Xperia support team for more information:
faisal3dfx
Alexander thank you for your reply. We all know that this problem is causing by the new 4.3 jellybean os. So it's not a hardware fault. So why should we go to the service center? What wilk they do about it? If there is any fix for this that can be done by a firmware update.
And of course Sony service center will not do a downgrade process. So what is the point to take and leave our phone in there???
If Sony can fix it they should release an update with all those bug fixed or provide us the kitkat version without any bugs.
