Xperia Tipo Device Storage
Anand_M_P
Hi, everyone my cell phone is Xperia Tipo dual and now I have got some trouble with device storage. Actually the phone works very smoothly and there is no problem with the performance. But then there is this fact that whenever I try to install new apps, I get the message “running low in disk space”. Now 90MB of the 700 MB is free and I am quite sure that, it will be filled soon. So what should I do to improve this? can I install apps in my ext card? Please help.
3 REPLIES 3
you can not install apps on your SD card unless you root your phone and then use apps2sd
you will have to delete apps or uninstall updates.
Anand_M_P
Thanks for the reply :smileyhappy:. But actually I did find a way to solve it. When the apps option from the settings is selected, there is an option to change the apps storage to the internal. This way we can save the phone memory to some extent. But if a lot of apps needs to install then this won’t work and the only option left is rooting I guess.
Indeed
