After upgraded to Android 4.3, the WiFi connection will suddenly dropped every 30 mins.
Even I power-cycle the WiFi router, reboot the Tablet Z but the problem still occurs.
I don't think the problem related to the WiFi router as there is no problem on my Z1 mobile phone which connect to the same WiFi router.
May i know anyone got the same problem like it? Also is there any workaround to solve it?
Best Regards!
Hi illusiongshock
the best way to fix is (most time it fixes this issue, including mine )
>remove all the networks in you phone using forget network, restart phone, then add the wifi network to your phone, as first network , then try it , it believe it works
let us know
Manjuboyz
NOTE:
Rate me(Kudos) If you are happy with my Resolution, Thanks
