Xperia T3 mute after screen lock
thefirstprince
I don't know what happen. I just bought Xperia T3 a couple weeks ago. Everytime I lock the screen, my phone turns mute, in every aspect. I can't hear a call, the phone is not ringing, I can't hear spotify, I can't hear key tone, everything's just mute. How to fix this beacuse it's kinda frustating.
Please help Slightly_frowning_Face
7 REPLIES 7
Thommo
Genius
Try Settings then Apps then tap the 3 dots then tap on Reset app preferences then reboot and test - Once rebooted you may find that other settings you had will need to be changed
thefirstprince
Thanks. It works at first, but then my phone mute again. Any other suggestions?
Phy
Legend
Legend
Try Clearing the SmartConnect app data.
How to clear data on apps.
From your Home screen
1. Tap the Application screen icon.
2. Find and tap Settings > Apps.
3. Swipe to the All tab.
4. Find and tap on the SmartConnect app.
5. Tap Force stop > Clear data.
6. Restart the phone
thefirstprince
Thanks Phy,
But it's not working Slightly_frowning_Face
Phy
Legend
Legend
Try repairing your phone with Sony PC Companion
Sony PC Companion.
http://support.sonymobile.com/us/tools/pc-companion/
thefirstprince
How to repair my phone with Sony PC Companion?
profile.country.RO.title
_alexdon_
Performing a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 80% battery.
alexdon
