from fast boot right clicked by holding shift >selected open command window here .. folder was quick unlock xperia t2 ultra files wew fastboot.exe boot.img and 2-3 more file ... unlocked boot loader ... nd flashed boot img(boot.img i copid from zip file mokee open soirce .
copide mokkes boot.img nd pressing shift right clicking frm fastboot folder gave command in terminal fastboot flash boot.img (boot img was of mokee)
in flashed from recovery menu that mokee zip file install successful .. but come to knowthis flah was for t2 ulyra not t2 ulrmtra daul(d5322) .. so meither network signal nor wifi was running.. than i searched on net download stock kernal for t2 ultra daul. nd same command window flashed that stock kernal by command fastboot flash boot.img ( that img was not mokee) .
than i was going to flash orignal stock rom frm sdcard ..but phone wont start up... than i keep presed powre botton... not started like dead nothing. pressed power n volume up singal vibration come n green led for second... kept pressed just .. thrice vibratin was coming on.... screen just blackout not even 1 alphabet or light from thatits dead...
then i pressed tinny reset button in sim micro sim slot near audio jack... form that time...
deadman walk again... started vibrating but not booting still
when connected charger only constantaly blink red led.. and when connecting pc red light than green light and nothing .. pc cant recnogise.. when repairin by sony comapin 2.1 its show u have modified version installed cant repaired.... when holdin power button and volume up.. vbrate once and later vibrate thrice.. i just holded it till thrice wibrated and put aside. and turn on normally but only 1 vibration comming with blinking 1-1 time red and green for a secondred
please help...only vibration and led ... phone not charging too when connected charger just keep blinking red led blinking constantaly... but not charging coz if it charge phone pin of usb cable near power adapter should be hot as usual and always it becomes
As your Bootloader is unlocked you have one option and that is to use Flashtools and a .ftf firmware file for your actual model of the T2 - See here or you could also try using Flashtools to relock the bootloader then use Pc Companion to perform a system repair
