Xperia T Won't Turn on and won't Charge, Also won't connect to PC to Repair
yannick18
my xperia t do not light on anymore
i ve tryed to reboot it by pressing volume up plus power even the 3 vibrations nothing work
it happend to me already and finally worked
but this time i dont know
Hampus
I suggest (if possible) that you try with another cable/charger to see if this can help. Since your unit does not react while trying to force a restart/shut down(ON/OFF button + volume up), it sounds more like a hardware fault.
If you still are unable to charge your unit or perform a software repair, I suggest that you contact nearest service center so a technician can examine your unit. You can contact your local support team for further information about nearest service center and how to proceed with this in the best possible way:
