Xperia T camera problems
sac110
I am having a problem when opening the camera, it just keeps flicking and the photos in the little screen bit keep flicking round and round not allowing you to take anything.
I have to switch of and reset each time.
Sometimes it will take a couple then start doing it, other times its when you rotate the screen.
Anybody else having this?
2 REPLIES 2
Johan
I suggest that you try to reinstall the phone software using SUS to check if it can fix this problem.
nye
I have the Same problem. did the reinstall with no change. The call volume on this phone also has a problem, during calls no matter how high the volume you could hardly hear unless you have a bluetooth device or on speaker. (sound setting at max)
