xperia sp touch problem
ekpreet
i bought my xperia sp a week ago.from the next day onwards i have started to face touch which sometimes is not recognized by my phone.i updated to the latest firmware but the problem still remains and it is even more during charging.all i have to do it is to enable and disable glove mode to bring it back to normal functioning.please help is there any solution to it or is it a hardware problem?
6 REPLIES 6
profile.country.RO.title
_alexdon_
First,you are in the wrong section.Secondly,I have to tell you that the touch problem is a very common issue for the SP,I have read a lot about it.The touchscreen does not work when the phone is laid on a flat surface,but when in hand it is ok.I recommend taking the phone to a sony repair center.
alexdon
gwhispererz
Moved. Slightly_smiling_Face
ekpreet
but the touch problem even occurs while in hand.is it some hardware problem then?
gwhispererz
If software repair/update did not resolve the issue, most likely it is a hardware issue.
Contact your local Service Centre to have your phone checked.
Don't forget to mark correct answer as Accepted Solution.
If you find the post helpful, press Kudos.
DY
HI MY SONY XPERIA SP TOUCH SCREEN IS CURRENTLY NOT FUNCTIONING. I CANT SWIPE NOR TYPE ANYTHING. I'M CURRENTLY CONFUSED. I NEED URGENT HELP. THANKS
DY
HI MY SONY XPERIA SP IS NOT FUNCTIONING. I CANT SWIPE NOR TYPE ANYTHING. I REALLY NEED URGENT HELP.
THANKS
