Any solution for this problem.
Thanks.
Just swipe up from home, go to settings - voice - ok google detection and try to disable OK google. If this does not help,please reply.
Sorry, but i coudn't find option "voice" in settings.
In Search and now setting. If this does not help,you may need to perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
I found but still appears bug. Thanks anyway.
Can you try the repair?
Yes via PC Companion/Support zone/Tablet software update and repair but still bug appears.
So you already performed the repair?
Yes.
In this case,you should have the device examined at a sony service:
I contacted them and they answered my mail:
Thank you for contacting the Sony Xperia support centre.
We are sorry to hear of the issues you are experiencing with your Sony Xperia SP camera crashing.
We would suggest that you try to perform a repair of the software using PC Companion. If the issue is related to a problem with your software this will be repaired and your handset will work as intended. To do this, you will need to install PC Companion from the Sony Xperia website. Please follow the steps below to do this:
To then perform a repair on your handset’s software, please follow the steps below, making sure that at the start of the process the device is turned off and disconnected from the computer:
Please ensure your handset is not connected to your PC when performing the above as you will be instructed to connect your handset once you have followed the above steps. Your handset must also remain powered off at all times.
Please note it may be the case that user data is lost during this upgrade. We therefore recommend backing up any data to your SIM card, Memory Stick, or PC before upgrading.
Please be aware that if an update to a later version of Android has become available for your Sony Xperia handset the new version may be installed. If this is the case you may notice some differences in the functionality of your handset when updating. All information regarding these changes can be viewed on the following link. We would recommend reading through the following before updating:
www.sonymobile.com/gb/software
We hope this helps you.
For the latest news, information and product support please visit
www.sonymobile.com.
If you require any further assistance then please do not hesitate to contact us again. Please use the below link for all our contact information.
http://www.sonymobile.com/gb/support/contact-us/
Please be aware that should you not respond within 5 days of this email your query will be automatically closed. Any further communications will not reach our support and a new query will need to be raised.
Kind Regards,
Stacey
Sony Xperia UK Customer Services
