Depending on software version and also branding the default led notification might be a short white blink every 5 seconds. You could try the following app which allows you to change color and length of the led: https://play.google.com/store/apps/details?id=com.rundgong.illuminationcontrol.
Check Light Effect in settings.
Settings >> Display >> Light Effect.
Make sure that you have enabled it for Unread SMS.
it's because of satmina mode is on.if u disable the stamina mode, it will work properly.
this issue will be expected to be solved in upcoming firmware update.this update will released in india soon.
Thanks for the info, I'm having the same problem......
Bumping this as having same problem. No stamina mode or battery saving, LED notification light is barely intermittently working.
So this phone has 2 big features: LED notification and STAMINA mode. And you can't use them both? 🙂
Anyway, I have the same problem. But turning STAMINA off doesn't seem to work for me!
Anyway, if that would be the cause, isn't there an app that can be put in the STAMINA exclude list? That way, STAMINA could be turned on after all.
illumination bar notification on google play store
