After updating my Xperia SP with the latest Android 4.3, I am unable to change my keyboard input method. Whenever I select it, the phone will restart immediately. I have restarted my phone numerous times but the problem remains. I have also selected 'repair' on the PC Companion but it claimed that there was no problem to be repaired.
Another problem that has surfaced is the volume. Whenever I use the volume keys, all that appears on the screen is this small rectangular box that does not indicate the volume level.
Please advise on this matter, thanks!
Tyr repair your phone by sus..
For volume indicater switchto default theme and reboot
Thank you both for your help; there was no need to reinstall the firmware nor repair the system...I just changed it to the default xperia theme and restarted - and both the problems were gone!
Thanks again for the help!:)
My problem is a bit different with you , my volume in handsfree is ok but after I unplug the handsfree the whole my volumes gone . is there any soloution for it ?
Have you tried clearing data for smart connect in settings-apps-all?
