this sony experia sp mean a lot to me but always died by it self while iam using it
always and always for many many times happenned just like that and even in charging possition but always died by it self
please help experia care and all friends here
You may need to perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 80% battery.
You need to make sure the device is charged for about 2-3 hours. After that, force it to turn off. Start the repair process and connect the device to your laptop only when PCC prompts you.
This is strange,maybe you can try on a windows XP computer? Or try to run PCC in compatibility mode with XP or 7.
