Xperia SP current issues
Fabregas
I found out these issues:
-WiFi problem <- Phone has weak signal or it has to be closer to router than normally.
-Display <- When kept horizontal, it doesn't register all actions.
-Camera <- Pictures "too" noisy. They're also more worst than pictures with similar Sony camera technique. (There's rumour that update comin..)
I'd like to hear what Sony's opinion to these issues and are these issues that they can fix, or should the phone to be sent to somewhere to get fixed? All these issues are kind of "major" issues, so these should be solved very quickly. And I think there is more to come for such a new model...
2 REPLIES 2
Johan
The discussion about Wi-Fi range has already been forwarded and I suggest that you keep discussing that in exiting threads.
Please share more info and elaborate about the display issue you're experiencing.
We always try to improve the camera in software updates along with other phone features. I will forward your fee3dback about the camera quality.
Xad
Is this WIFI issue related to the problem AirDroid is having with Xperia SP? In that if you lock the screen of your SP or the screen turns off, then AirDroid's connection to your PC gets cut off and you have to turn the screen back on and keep it on as long as you're using AirDroid which uses up unnecessary amounts of battery power as the screen is not really being utilised.
If it is separate can you please forward this bug onto the developers. Or is this a bug with AirDroid itself? I imagine it has to do with SP as AirDroid works flawlessly in my XperiaS and my S5830.
Also, agree with OP that camera can be improved a lot. Hopefully an update similar to the Xperia Z update is coming since i've read some Xperia Z users saying their update improved the camera a lot.
