Xperia sp charging problem
hammouda
6 hours ago my sony xperia sp was charging without problems. when I got home a few minutes ago it has 5% charge. when I connected it to the charger it shows no reaction!!! i doesn´t want to charge!
PLS! i need help because I need the phone tomorrow! its really important!
4 REPLIES 4
discretion1
Try connecting to different charger, or to a PC's USB port. Your charger could be faulty. Or try this - switch off your mobile and then remove the sim card and the memory card. Keep it so for a few minutes. Then connect to the charger. If it works, leave it at that for some time,  then switch it off and insert the sim and the memory cards. Also take a look at this thread:
http://talk.sonymobile.com/t5/Xperia-L/Xperia-L-C2105-does-not-charge-if-it-is-off/m-p/340080#M850
hammouda
no.. nothing.. there is no reaction... i also couldn´t find any solution in the thread
discretion1
Then you should probably take it to a Sony service centre.
ianwitten
try turning around the cable in the port works for me but it is very annoying
