Xperia SP (C5306) Boot Problem after Failed Update
silentscream4
Hello,
I was updating my phone Xperia Sp (c5306) to 12.0.1.207 update but it failed due to internet problem. Now i boot my phone it won't boot it goes to sony screen and then it shutdowns.
Can you guide ?
4 REPLIES 4
profile.country.RO.title
_alexdon_
You may need to perform a software repair using PC companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
alexdon
silentscream4
Thank you!
This solved the Problem
_alexdon_
Great.
alexdon
GregM1031
Hello guys!
I've the same problem there. I tried to reset my phone using the off switch and it vibrates 3times. But when I plugged in to a wall charger, the phone tries to start, the green led turns to red, the sony logo appears and turns off itself. Plesae help me.
