xperia sp 4.3 problems
Saddamjit
Xperia SP is very good phone but with 4.3 it works like **bleep**..
It hangs and freezes often
Uninstallings hangs phone many applications crash inclusing xperia home.
Screen flickring is frequent
10 REPLIES 10
GreekXperiaSp
Have you tried to repair it or hard reset it with pc companion or SUS?
Danial-mach1
Leader
go for a reset to factory
Elmo5
Disable chrome updates to factory settings. It frees up 100mb more ram and makes your phone lot faster.
This is a lot easier, faster and better trick than a reset to factory settings.
Danial-mach1
Leader
disabalin crome may not work for anyone
spicialy for how didnt update their chrome and stuck with good old one
Elmo5
Danial-mach, is there a proper way to back up the phone to restore it easily after a factory reset. I havent found a perfect one. Back up to sd is ok but it doesnt restore the home screens. Sony bridge for mac back up is a piece of crap.
Danial-mach1
Leader
http://talk.sonymobile.com/t5/Xperia-Ion/Alternatives-on-How-to-backup-Xperias/td-p/161240
read this
also you can try biult in backup app
but i doubt if any one of them can bring the home screens back
(you mean your arrengment on icons or wallpaer and else?right?)
Elmo5
Yes, i mean the screens i can configure myself. I find tesetting to factory complicated. And it has to be done frequently. Therefore disabling chrome updates seems much better. After all, chrome gives a lot of trouble, although i thought it was solved with 201. But it isnt.
Saddamjit
othing happens. phone is still laggy.
Saddamjit
Saddamjit wrote:
Problems in update
1.Phone still lags and crashes occur. When it lags Power button stops working.
2.Wallpaper flickers when Home button in pressed from menu.
3.Xperia Home crashes and phone hangs.
4.There is little improvement only. I suggest you not to update .
5.Phone takes time to launch an application.
