HI , i have recently purchased sony XPERIA SL , and its running on ICS .. i have noted the following
IDLE TEMPERATURE - 37 C
MODERATE USE - 40 C
GAMING (TEMPLE RUN , SUBWAY SURFER) - 47 C
THE POWER MANAGER INSTALLED IN MY PHONE GIVES A POPUP WARNING WHEN THE TEMPERATURE REACHES 46 C
even after 10 to 20 mintues of gaming , it goes up to 46 C .. which is very hot actually..
IS THIS NORMAL ?? DO I HAVE TO TAKE MY PHONE TO SERVICE CENTRE ??
PLS PLS PLS HELP...
- NEW AND DISTRESSED SONY USER..
actually it is normal. as long as it doesn't exceed the recommended temperature as stated on the white paper ( you can download it on products page)
but if other stuff happens such as burnt smell, then its time to take your phone to a local service center,
i suggest also to uninstall unnecessary apps like battery/ram saver booster. task killer etc.
" as stated on the white paper " ??? could u please clarify ???
I have downloaded the white paper.. But it says nothing about the operating temperatures..!!
i also bought XSL on 21st feb..
i suppose there is a problem with the jan/feb 2013 lot of this phone...
my phone also got heated when playing 5-10 mins of stick cricket, temple run 2 etc..
plus the screen of the phone has yellowish tone at the bottom... (not the Xperia s patches)
went to the service centre,,, 5-6 ppl were there with their XSL (recently bought) having the same issue (screen/heating)
now they are replacing my phones motherboard, digitizer and screen...
totally dissapointed by sony's product quality....
previous Xperience (neo v, w810i) were much better and solid....
Hi Bro, i too facing the same issue , please let us know it after replacing these parts everything works fine or not ??
