Xperia S will not start
xperiaS_RIP
Urgent help needed with xperia S. Was using phone when it froze, tried to restart but remained frozen, so i tried rebooting, it came back on but it froze again on the SONY when restarted, so i tried to reboot again and now it just not responding at all. Please help....how can I get my phone to work again?
4 REPLIES 4
Thommo
Genius
Run a repair using either PCC or SUS found here http://www.sonymobile.com/global-en/tools/update-service/
2. Download a .ftf file and using Flashtools manually flash your phone - A good guide for doing this can be found here http://www.xperiablog.net/2013/05/30/install-jelly-bean-to-your-xperia-s-using-flashtool-tutorial/ and a list of firmware can be found in various places 1 been XDA here http://forum.xda-developers.com/showthread.php?t=1599303 and Xperia Blog here http://www.xperiablog.net/forum/resources/categories/xperia-s.19/
xperiaS_RIP
Thank you so much for the reply...I will try one of the above. Hopefully it works Slightly_smiling_Face
shihstouch
Enthusiast
Restart
Restart your phone to turn off all running applications and to free up memory. Press and hold down both the volume up key and the power key Power key of Sony Smartphone for 10 seconds. After your device vibrates three times, release the keys. The device turns off automatically. After the device is turned off, restart your phone.
The phone freezes or applications suddenly shut down
Downloaded applications can cause the phone to behave unexpectedly or affect the phone performance. Use safe mode to check if any downloaded application causes the problem. In safe mode, the phone only starts with preinstalled software and applications. If the phone performance improves in safe mode, it’s likely that one or more of the downloaded applications are affecting the phone negatively. You can then uninstall the most recently downloaded application and restart the phone.
To enable safe mode
  1. Turn off the phone.
  2. Press and hold down the power key Power key of Sony Smartphone until the phone vibrates.
  3. Wait until the Xperia™ logotype disappears.
  4. Press and hold the volume down key until the phone vibrates. The phone then restarts in safe mode.
Note: To exit safe mode, restart the phone.
shihstouch
Enthusiast
I cannot power on my phone
  • It might be that the battery is drained. If the battery is completely discharged, the phone needs to charge for a while before the battery status light lights up. Charge the battery for at least 30 minutes, and then turn on the phone.
    More
    To turn on the phone
    Note: Make sure that the battery is charged for at least 30 minutes before you turn on the phone for the first time.
    sony-xperia-s-on
    1. Press and hold down the power key Power key of Sony Smartphone until the phone vibrates.
    2. Wait a while for the phone to start.
