Hello,
I have Wifi and Bluetooth problem with my Xperia S. I cant turn them on. While investigating with a local repair person, I found that the antenna has been broken. Can you please help me with the cost of Xperia S antenna and is it possible to get it replaced and solve this issue ? I also have volume key issue where in the key is jammed (works but not smooth) and it sometimes make the power button irresponsive. Is there any solution to this jammed key as well ? Please help ....
FYI ... I am from India ...
Regds
Hi, for hardware problems, you need to send it to service centre for repair.
Contact your local service centre, they should be able to assist you regarding your queries.
