Xperia S problem
Aaron064
Xperia S problem
My phone when switched on, Sony logo comes and then a repair sign. Usually the repair sign used to be there for a minute max. but now the repair sign stays for 10 minutes and then shows some caution sign. I tried to factory reset using PC companion, after preparation of computer and download of software , updating of the phone doesnt happen. Please help.
6 REPLIES 6
profile.country.RO.title
_alexdon_
You may need to perform a software repair using PC companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
alexdon
Aaron064
I did the same. Followed all steps. Then a software gets downloaded on to the computer and then it should update the phone (so as to repair). But the updating of software into phone itself fails.Charge on phone should be more than 50%? My phone is switched off. I connect for charging using wallcharger. Charges for sometime then sony logo comes and again repair symbol appears. Does the phone charge when the repair symbol appears?
_alexdon_
It should.Can you try to keep it connected to wall socket for 3 hours? If that does not help, I think it would be wise to stop by a sony service.
alexdon
Aaron064
Ok thanks.
_alexdon_
Keep us updated.
alexdon
Rickard
This screen means that something has happened with the file system and the phone is fixing the issue. It may take up to 24h but it's usually faster. Please connect a charger and wait for the repair to finish.
