I updated my xperia S to ICS firmware 6.1.A.2.45 with Flashtool. Everything is ok expect NFC. I cannot turn on NFC in my phone. It cannot be loaded. How can I do?
Hi, im having the same problem now...
i would love to see an answer for it...
repair your phone with SUS and elaborate on your issue
Update Service (SUS)
http://software.sonymobile.com/install_packs/Update_Service_Setup-2.12.12.41.exe
I tried it... i even reinstalled the version (and it deleted most of the information i had on the phone, fortunatly enough i backed up the phone before so i have most of the things back)...
it didnt solve the problem, im still unable to enable the NFC in my phone
Hi
I too have the NFC issue - I can not turn it on.
Since ICS update the NFC will not activate.
I have tried the repair option 3 or 4 times over a couple of months and still no change.
It just won't turn on.
I check the NFC box under Wireless & Networks - the tick appears in the checkbox, the NFC box dulls to a light grey and 6 seconds later the checkbox unchecks and the NFC box goes back to the bright white font.
I have tried using the tools widget to turn on the NFC and all I get is a blue halo in the NFC box turning for about 5 seconds and then nothing.
Am I missing something or is there an underlying issue at work here?
I have also uninstalled AVG and rebooted the phone - this has also had no effect (although this didn't serve as an issue before the ICS update).
Please, somebody, anybody, can you help - hopefully it's something simple that'll leave me red faced....
Message was edited by: Drewboi I have just tried the NFC test in the hidden service menu - NFC Diag Test The NFC device can not be used. OK
