Xperia ray WIFI connectivity problem
I have xperia ray.
when i connect to wifi it shows connected but there is no internet access.
the router works properly on other devices.
what to do??
20 REPLIES 20
Nabeel
Hi Slightly_smiling_Face
have a look
Yes sir i did check it before posting the query.
I even tried all what that was given, even updated the router firmware, but still no positive result.
The problem does not occur everytime,it happens randomly like i used wifi perfectly for sometime but when i reconnect there is no internet access.
My android version is 2.3.4 and build number 4.0.2.A.0.62 (if needed)
the problem is with Android 3.2 when we use the Dynamic IP assigned by the router. details in the link below -
http://support-remote.splashtop.com/entries/20413941-why-am-i-getting-disconnected-after-only-a-few-...
the resolution. set up a static IP on your android phone. how to do that...
first you would need the IP, Subnetmask and default gateway. If you have a PC that is connected to the same router. you could get that by following the steps mentioned in the following link
http://portforward.com/networking/static-win7.htm
Once you have these details -
1.) go to settings>wireless options>wifi settings
2.) now click on the menu button
3.) go to "Advance options"
4.) cick on set up Static IP address
NOTE: the steps below here are per wifi specific (you would have got these details from your Pc by following the above link)
5.) enter IP as 192.168.1.10
6.) enter subset mask : 255.255.255.0
7.) default gateway :192.168.1.1
i am facing the same problem. please let me knowm if you got the solution ([email protected]).
looking forward for your reply.
Hey thanks for the help now the wifi connects properly without any problem.. Slightly_smiling_Face
one more query do i need to use static ip everytime or can i switch to dynamic ip if using other router ??
yes the problem is solved by using the static ip
i have tried the static IP aswell. but the result is the same. no access.
i am providing the IP address that i had issued while using stating IP.
ip addess: 192.168.0.100 --- (this IP i got from router, it was showing this IP against this device)
gateway: 192.168.0.1  -- (router's IP)
netmask:255.255.255.0
DNS 1 : 192.168.0.1
DNS 2 :  192.168.0.1
let me know , if it is right way to do or not!
thanks and regards//
yahoo.... its working now.
i reinstalled wifi router driver. and then BINGO!!! Slightly_smiling_Face
ok.. Slightly_smiling_Face
can you plz tell me about the camera quality?
The camera quality is not as expected of a 8MP camera.
The size if images is around 1 mb while other 8mp have it around 2-3md  and the ISO is as high as 500-600 while others have it as 100-200.
Is there any solution to this??
