Xperia ray Wi-Fi problem and video recording on 4.0.4
dineshlives
Hi sony i have bought a xperia ray before 2 months now im updated to 4.0.4
and the problems i get is
1. wifi error
my Galaxy fit is working fine with wifi
But ray is not working fine it connects to modem but no data connecton
i have connected the two devices on the same modem...............
pls watch these videos and pls help to resolve the problem..........(I got this problem only after ICS update (4.0.3 and 4.0.4))
GALAXY FIT - http://youtu.be/f68kuMQhgiohttp://youtu.be/nRQ1Nh6LN3I
XPERIA RAY - http://youtu.be/f68kuMQhgio
and video recording error- video records like taking photos in burst mode
ill upload a video for that later
8 REPLIES 8
aravindad
he problem is with Android 3.2 when we use the Dynamic IP assigned by the router. details in the link below -
http://support-remote.splashtop.com/entries/20413941-why-am-i-getting-disconnected-after-only-a-few-...
the resolution. set up a static IP on your android phone. how to do that...
first you would need the IP, Subnetmask and default gateway. If you have a PC that is connected to the same router. you could get that by following the steps mentioned in the following link
http://portforward.com/networking/static-win7.htm
Once you have these details -
1.) go to settings>wireless options>wifi settings
2.) now click on the menu button
3.) go to "Advance options"
4.) cick on set up Static IP address
NOTE: the steps below here are per wifi specific (you would have got these details from your Pc by following the above link)
5.) enter IP as 192.168.1.10
6.) enter subset mask : 255.255.255.0
7.) default gateway :192.168.1.1
hopt it will solve your problem..
SOURCE : http://talk.sonymobile.com/message/180154
Veresova
The video is a non-standard input PIN.
I have ray 4.0.4 on ICS other.
You have some modifications?
Markus1
Leader
Have a look at this thread to see if any of the posted tips can help you.
http://talk.sonymobile.com/message/154244#154244
dineshlives
Tried every thing in that post
Setting static ip just makes the mobile to connect faster to the router
but no change on loading............
Markus1
Leader
If you've tried all those tips (including trying to connect to a different network) and it still does not work, I suggest you first of all perform a factory data reset. Do this at Settings > Backup & reset > Factory Data Reset.
Make sure to backup all data in the phone memory before you do this as this will be wiped.
dineshlives
Nothing works - Slightly_frowning_Face
Not only i have this problem.............
another one person commented on my youtube video also has
Sony must solve this ----------- pls
I have just disabled UPNP and Gaming Mode on my Dlink router (Advanced Networking settings) and now it's working fine.
Did a factory reset and SD erase before changing the router settings.
My security is WPA and TKIP
dineshlives
SAME PROBLEM no changes
done this too
and now i bought a new router too
same problem in that too
