Xperia Ray Rear Camera Force Close
Hi I bought an Xperia Ray, which had some evidence of water damage. Everything works fine except the rear 8M camera.
Everytime I open an application that uses the rear camera I get a force close and application ends.
Everything to do with the front camera works fine.
Any ideas please?
2 REPLIES 2
Veresova
SCP - Service Center Phones Slightly_smiling_Face
Sam
Legend
Legend
Veresova's answer is likely the correct one in these types of cases. However if you are just getting a force close on the camera then I would advise that you try this as well:
Main menu > Settings > Applications > Manage Applications > All > Camera > Clear data.
If this also fails to resolve the issue then you may want to try a firmware update as a Force Close error is unlikely to be due to the hardware damage.
