Xperia ray can not turn on after installation failed!
Rubel
Dear Xperts,
I have been using xperia ray for about more than one year.
Today i want to update the software from GB (2.3.4) to ICS.
During the time of update(PC companion), when computer installing software to mobile, it shows "installation failed".
After that i alos try Sony update service but got same message.
Now i can not power on my mobile. If i connect charger, then nothing happens. But if connect to the computer then only Green led light.
Note: I tries to Hard reset by pressing Power+volume down key but nothing happen. Then press power+volume up key then Blue led light.
Whats happen... Plz plz plz reply me..
9 REPLIES 9
Alexander1
I suggest that you remove the battery from the phone for a while. Put it back in and charge for a couple of hours using the wall charger. If you still can't start the phone I suggest that you try to repair the phone using PC Companion:
In PC Companion, press start on Support Zone > Start on Update the phones software > Press the blue link that says "Repair phone". Do this without the phone connected and then follow the instructions given to you in the program.
Rubel
Dear Alexander,
Thanks for your reply.
My phones battery is full.
I do as per your suggestion. There are 4 steps in PC companion: 1.Start  2.Prepare  3.Update  4.Fininsh
In the stage of "Update" , it shows following message:
"An error has occured and the phone software update was cancelled.
Your phone/tablet may be damaged.
It is recommended that you retry and repair the phone/tabet with the latest available sotfware.
Click retry and follow the guide."
This is very unfortunate, plz help
Alexander1
You could also try to update/repair the phone software using Sony Update Service instead of PC Companion:
Rubel
I have also tried to SUS but it also shows installation failed !
PC companion show the following message:
If i close the message then it shows:
Sony Update Engine Failure (error 100)
I am very warried about my hardware, is there any problem in ROM?
Note: When SUS/PC companion wants to  connect the phone by pressing volume down key, my phone can connect without pressing the volume down key and green led light.
Every steps i followed as per SONY recommendation but why this happens?
I have no warrenty.
Plz help.
Rubel
Dear Alexander,
I also use flastool (v0.9.13) and official ROM (4.1.B.0.587) for xpreia ray but failed!
Log:
13/058/2013 10:58:21 - INFO - <- This level is successfully initialized
13/058/2013 10:58:21 - INFO - Flashtool Version 0.9.13.0 built on 2013-06-04 22:50:00
13/058/2013 10:58:26 - INFO - Device disconnected
13/058/2013 10:58:43 - INFO - Selected ST18i / 4.1.B.0.587 / CE_1252-3693_ForsakenNGL
13/058/2013 10:58:43 - INFO - Preparing files for flashing
13/058/2013 10:58:53 - INFO - Please connect your device into flashmode.
13/059/2013 10:59:01 - INFO - Device connected in flash mode
13/059/2013 10:59:01 - INFO - Opening device for R/W
13/059/2013 10:59:01 - INFO - Reading device information
13/059/2013 10:59:01 - INFO - Phone ready for flashmode operations.
13/059/2013 10:59:01 - INFO - Current device : ST18i - BX902ZD10Q - 1252-0948_R1I - 1248-9545_4.1.B.0.587 - WORLD-i_4.1.B.0.587
13/059/2013 10:59:01 - INFO - Start Flashing
13/059/2013 10:59:01 - INFO - Processing loader.sin
13/059/2013 10:59:01 - INFO - Checking header
13/059/2013 10:59:02 - INFO - Flashing data
13/059/2013 10:59:04 - INFO - Loader : S1_Loader_Root_773f - Version : R4A066 / Boot version : R9B031 / Bootloader status : ROOTABLE
13/059/2013 10:59:04 - INFO - Disabling final data verification check
13/059/2013 10:59:04 - INFO - Processing kernel.sin
13/059/2013 10:59:04 - INFO - Checking header
13/059/2013 10:59:04 - INFO - Flashing data
13/059/2013 10:59:06 - INFO - Processing fota1.sin
13/059/2013 10:59:06 - INFO - Checking header
13/059/2013 10:59:06 - INFO - Flashing data
13/059/2013 10:59:06 - INFO - Processing fota0.sin
13/059/2013 10:59:07 - INFO - Processing adsp.sin
13/059/2013 10:59:07 - INFO - Checking header
13/059/2013 10:59:07 - INFO - Flashing data
13/059/2013 10:59:09 - INFO - Processing amss_fs_urushi.sin
13/059/2013 10:59:09 - INFO - Checking header
13/059/2013 10:59:09 - INFO - Flashing data
13/059/2013 10:59:09 - INFO - Processing amss.sin
13/059/2013 10:59:14 - INFO - Ending flash session
13/059/2013 10:59:14 - ERROR - ERR_SEVERITY="MAJOR";ERR_CLASS="MEMORY_CLASS";ERR_STATIC="HASH_VER";ERR_DYNAMIC="Block verification failed";
13/059/2013 10:59:14 - ERROR - Error flashing. Aborted
13/059/2013 10:59:14 - INFO - Device connected in flash mode
13/059/2013 10:59:15 - INFO - Device disconnected
13/059/2013 10:59:17 - INFO - Device connected in flash mode
What is the problem?
Bal_K
Hi
I have had the exact same problem. I have also tried to update the software for the first time since I first bought the ray.
I have also tried the solutions suggested but it still wont work.  Please could you advise how I get my Experia Ray to work?
Or whether anone knows what a possible solution is to reboot/reformat the phone?
Thanks
Alexander1
In that case I would suggest to try to update/repair the phone software using another computer, perhaps on another network.
If you still experience problem I would suggest you to have the phone examined at a service center. Please contact your local Xperia support team for more information:
Sumit25
My sony ericsson xperia neo v is also facing same problem...
Alexander1
Have you tried the suggestions above?
