Hi All,
I purchased a Xperia P a week ago and from the start I was facing a peculiar network problem: the network would disappear for 5-10 seconds after every call and then magically reappear. First, I thought that the problems were related to SIM , which I had cut myself, so I went ahead and bought a new micro SIM from the service provider. But still the problem persists. I am clueless over whole issue , could anybody please help meout here,,,IS this a software bug or a hardware bug??
Also, sometimes there is a total loss of network and the phone has to be restarted.
The specs of the phone are as below:
Model - LT22i
OS - Android ICS 4.0.4 - came preloaded with it.
Kernel Version -3.0.8+
Build No : 6.01B.0.544
Thanks in Advance!
Hi All,
Having the same problems here...any suggestions
Thanks.
Hey, well thts prolly coz the network is in dual mode... i e wcdma/GSM
You have to select any 1 of these...n tht should solve the problem...Select GSM if your active on 2G n wcdma if 3G...cheers
Thanks Jayesh, will check if that solves the issue..thanks again.
