Hey guys...whenever i enter in roaming area, i hav to manually search for a network which takes 5-10 mins. My network selection is automatic, still whenever i go out of state it does not catch network automatically. I have to manually set the network. Kindly give me some solution.
Also, how can we select multiple songs from walkman if we have to delete or send via. bluetooth more than one song.
Also i just tried to upload a video on facebook by going to albums then selecting the video then by sharing it using sharing icon which appears on the top middle of the screen. The problem is, it failed to upload for the first time so i decided not to upload it. but in notification bar of my phone new notification appeared automatically showing: Facebook upload 1 of 1. Now i don't know how to get rid of that notification and i certainly don't know whether it is actually uploading the video or not. As it is not increasing from 0%. also, there is no cross sign on the top right of notification bar.
Ok first with your network..try using another sim card to see if theres a network issue. I once got a problem wherein i cant connect to gprs/3g network. I tried using a new sim card and th issue was solved.
Second,to delete or send multiple songs, use astro file manager to be able to select multiple items/files and you can delet it or send via bluetooth as many as you want.
With facebook issue. Try to uninstall updates and try to upload video if still problem persists have a software repair using pc companion or SUS
Hope it helps
How can my sim be faulty when it is working absolutely fine in the state itself, and when i manually search the network while in roaming it works perfectly. I just want to know why phone is not searching for the network itself!!
And regarding the walkman problem, it's too bad i hav to install a file manager as sony hasn't provided an option of multiple selection while it has always been famous for it's walkman series.
im just giving you idea..its all in you..if you dont want to try it then so be it..im just giving you an idea cause i once had this problem..
walkman app is great but as i said its all in you..if youk want to pass multiple files use the astro file manager..its a preinstalled app on your xperia device you dont have to download it..so its not bad at all.
As florenzgonzales says, i would recommend that you try your phone with another SIM-card. Which networks that are preferred has to do with the SIM-card. If there's no preferred network you need to select manually.
