Hi
I bought a xperia P, used.
I think that the motherboard are a problem, because:
1.When i delete the intern memory or make a factory reset in my phone, after the reset the phone in the memory appears the all files, before i delete the memory.
2.When i connect the phone in fastboot or flashboot it is not possible, because i have s1 boot download problem or s1 fastboot download problem, but i installed pc companion, flashtool driver and all drivers.
So i dont know to make a firmware update or else.
Any idea???
Have you tried to erase all information on the Internal storage via Settings > Storage?
Which computer OS are you running on? And also is it a x86 or x64 bit system?
Yes, I erased all information on the Internal storage via Settings > Storage.
I use windows 7 x64.
If possible check if you can perform an reinstall of the phone via SUS on a x86 system.
If not I suggest that you contact your local support team to have this examined and fixed at a repair center.
