I have an Xperia P model. after the last update of the android software, teh system is showing lots of issues.
1. All the noticiation sounds are disabling automatically. after restarting the system it will act as normal. but later on going back to the same stage.
2. No picture is visible in the album.
3. Auto-rotation of the screen is automatically disabled.
4. The phone is always getting hang or delay when using abroad
I have purchased this model in April 2013. Kindly suggest the resolution
Regards
Anoop Nair
You should try repair using PC Companion once again. It will reinstall your firmware and most probably will solve your issues.
1. its a bug and the solution is disable the default notificaiton to silent then all your msg, apps tones starts to ring,,
2. install this https://app.box.com/s/ep07u7g1gp0d4w2g44fs as normal apk and clear data and cache from settings, apps, all, album :smileysmileythumbsup:
3. it default
4. if it hangs always follow this
1. data reset (it deletes all your contacts, msgs and downloaded apps so do a backup and try)
2. install the update using pcc or sus
3. again to a data reset
