Xperia P build info
Xperia P build info
Hi guys plz let me kno which is the build version u guys ve?
I ve been seeing posts tht a new update was released for the screen being more yellow and also just saw that battery life has improved wit the new update.
12 REPLIES 12
http://www.ptcrb.com/vendor/complete/view_complete_request_guest.cfm?modelid=21036
HW VersionSW VersionRequest TypeDate Certified
A6.0.B.1.576ECOMay 17, 2012
A6.0.B.1.536ECOApr 27, 2012
A6.0.B.1.565ECOApr 27, 2012
A6.0.B.1.564ECOApr 27, 2012
A6.0.B.1.514VariantApr 27, 2012
I have 6.0.B.1.564 in my phone however the link says 6.0.B.1.576 is latest. PC companion and SUS says I have the latest software Slightly_frowning_Face What should i do?
you have to wait unltil its released on your country, unless you want to manually update your phone
Hmmm battery is draining really fast. I had a Ray b4. It wasnt the same wit Ray. This is really bad that Sony has not yet released the update in India though the phone is already released and when many re facing the problem.
how fast is it draining? if it last about 8hours with heavy use, it's normal, you have a higher deffinition screen than the ray and it is bigger after all.
Yeah, Xperia P has a much bigger screen than Ray (4" against 3,3"), and some genius at Sony decided to give it a smaller battery (1305 against 1500 mAh)....How dumb is that ?
I agree, for some reason Sony keeps making the screens bigger and HD (which is awesome) but shrinking the batteries, someone needs to get ...
It is not lasting even 4 hours with heavy usage. I have been browsing and using whatsapp. Clicked few photos and recorded some video. I had full charge. N after using it for 4 hours battery status is like 32% Slightly_frowning_Face
lets try this, press both power button and volume up, now charge it 100%, use it as you normally would, once you get to 10% go to settings -> about phone -> battery use
take screenshots -> tap on the graph take screenshots -> press back -> tap on each item on the list and copy their amount of hours/minutes each was on and post it all here.
