My xperia P's screen doesn't work anymore and when i try to connect it with pc companion to repair it it says that i have to unlock the screen but i'm not able to do that since my screen doesn't work. (the leds still work) PLEASE HELP
hardware problem man
You can run the repair without having the phone powered on if you follow these steps:
and install it on your PC.
4. Phone Software Update.
5. Start.
6. Repair Phone
7. Continue
8. Accept data removal
9. Next
10. Wait for prepare
11. Select Phone
12. Follow the connection steps
have you tried a force shutdown (pow button+vol up) until the phone vibrates 3 times?
