XPERIA NEO L BATTERY CHARGING PROBLEM??
Roadkill55
I bought this phone last year in August and it has been working fine until now. After connecting on the wall charger it doesnt get charged. Sometimes it charges upto 60% but later it discharges down to 0 even after being connected to charging. The LED stays on while charging but battery percent remains the same. completely discharged, its dead now. I took it to the centre and they returned it yesterday with 30% battery..i connected it to wall charging again and its showing the same problem..it wont switch on..the display is blank. The LED blinks for 30 seconds and stops..its been connected for over 6 hours it still wont switch on. They said the battery is ok.
I have 3 separate chargers so i guess its not a charger problem. I tried taking out the battery, tried usb charging and some other tricks i read in similar threads but nothing worked.
What do i do??
4 REPLIES 4
Johan
I suggest that you contact your local support team to check how to proceed with this since the phone has already been into the repair center once.
sps
Bro me too facing same problem, nobody helping, i went to service centre also, they said change the battery, but they are not providing me the same even on chargeable basis also.
In simple words, its the worst phone and sony should feel ashamed of this.
iamian
I have the same problem. When im charging my phone, the battery indicator says its charging but it is discharging in its own. I've already used 3 different chargers. But still the problem is there.
rakeshnew4
sir,
      i am using sonyxperia neo l phone with a bateery type BST-41  1500 mah,3.6 volts.
           my problem is the bateery draining so fast and charging so late.i think that the battery is not correct to that phone.so can u tell me that which battery is suitable for this mobile and speicifications needed to the battery.and someone said that to use BTC -ERX1XL battery with 1700mah and  3.7 v.
