Xperia neo does not start
After shutting down and charging i can not start my Xperia neo anymore. No start screen, nothing!
Tried to remove and insert the battery/sim/sd again, still no start-up.
Tried to charge it again, no led indicator...
Tried a hard reset, also not working....
Battery broken down? I'm not sure.
13 REPLIES 13
Nabeel
Try with other battery if possible
gwhispererz
Hi, suggest leaving phone to charge for some time.
Will try, but have to buy other battery first.
Also tried that for a few hours, without result.
Nabeel
Don't buy
Visit your service center if its quite near to your house
or try software repair
gwhispererz
Before you invest on another battery, test with another USB cable.
Thanks for the suggestion, didn't think of that.:smileysilly:
Tried that just now. Phone still doesn't start.
gwhispererz
No problem .... I think you have no choice but to test with another battery as I doubt you can do a software repair. Try to borrow one from friend using the same phone.
Tried this with both, PCC and Update Service, and two USB cables, original and other USB Cable.
Phone doesn't respond at all.
