Hi
Recentlry i update my miro to latest version. but my WiFI connection is working. I am not able to turn ON WIFI as well.Please help me to solve this.
What happens when you try to turn on Wi-Fi in the phone? Does it show that WiFi is enabled but no networks are detected or doesn't the phone show that WiFi is enabled?
Please check this thread first if you haven't done so already: http://talk.sonymobile.com/message/154244#154244.
Hi Rickard,
Thanks for reply.
I am unable to turn ON Wifi connection.I think it is deactivated as nothing happen when i try to ON-OFF Wifi Connection. Please let me know if there are any setting need to be updated.
sir..i have the samep roblem to...when i tried to turn my wifi...it cant turn on...it not like i cant conect to any network...but it just trying to enable the wifi but still cant enable...i even trying to se in my system service state and it say my wifi in unknown state...plz help sir
My Problem is bit more Sever...
I tried reset phone/removed battery/reset router ...
i checked http://www.wi-fi.org/ for certification and its there Linksys WAG120N
it doesn't show my wifi or other nearby wifi in neighbors house shows in my laptop.
i tried manual add with wifi with SSID and list still empty!
so what now! any idea how to fix this problem?
Hi
I have almost the same problem with wifi, or actually I should say more complicated.
I recognized the device restarts automaticlly every few days and after that it does not work to change the wifi state. Also if I enable the Data it does not really work and I can not exchange any traffic. The same problem appears every time I turn the phone off and on again. In addition when I install a new application the reset intervals get shorter and sometimes it happens several times a day!
Updating the phone did not help. And the only solution I found so far is restarting the phone a few times, and waiting something like 10 minutes
