My mobile (Xperia mini st15i) has problem with sensor keys as it keep on close application as it starts & gives back to running application what shall be the solution for it.
I suggest that you try to run a software reinstall using SUS.
If the problem still remains you should contact your local support team, to have the phone examined and fixed at an repair center.
