Hi there,
I have bought a XPERIA MINI PRO SK17i withouth the instalation cd.
The phone works fine but when connected to my comp. (windows xp) via usb it is not seen / picked up by PC Suite for Sony Ericsson.
I connect in media transfer mode.
The phone is detected by my computer as a cmera SK17.
I would like to make it work with the PC suite though. (and set up tethering also)
I think I need the Driver installed. s there anywhere I could downloade it from? I googled but no luck at all .
Thank you for your help.
The drivers should be installed automatically when you connect the phone. You are unable to download them separately.
Check the following thread:
http://talk.sonymobile.com/t5/FAQ/USB-connection-problems/m-p/348074
I had the same problem, but I solved it using this link:
In short:
Remember: you must use WinXP SP3.
Download the tetherxp.inf file to your computer
Configure your phone to tether
Connect computer and phone with the USB-cable
Install driver.
Afterwards it works every time with no extra setup on either phone or computer: just connect the cable.
