Xperia Mini Pro SK17i - Extream Battery Drain FW 4.1.B.0.587
CrashOverride
I upgraded my SK17i to the latest ICS 4.1.B.0.587 and there is extream battery drain while the phone is on stand by. I tried repairing the phone and reflashing with flashtool, still the same problem persists. Please see the below screenshots. The phone has been idle (No use at all) and the time without signal is 0%. Guys please understand, what we need above all advanced features is EXCELENT BATTERY LIFE! Please elaborate what you have done to make the battery drain faster?
AND... When can we expect a fix? Please release one ASAP, my phone is almost useless as it lasts 3-4 hours now with light use!
Screenshot_2012-10-17-15-56-05.pngScreenshot_2012-10-17-16-04-23.pngScreenshot_2012-10-17-16-22-10.png
15 REPLIES 15
CrashOverride
And now I figured out that the battery drain happens only when the phone is on 3G standby. When it is on GSM (Edge) there is NO battery drain!!!
Please help with a sollution.
Thanks!
ppgsk17
If you are facing battery drain problem while using 3G network then try to verify it with other netwok's SIM as low network causes battery to drain faster!
CrashOverride
I have always had the same provider. The battery drain started after the software update. And as you can see from the screenshots above the network signal is excelent!
ppgsk17
This is Edge network means GSM not 3G!
And I have obseved that on some 3G networks though the signal strenght is full battery drains faster while on others battery lasts long.
Thats why give it a try.
CrashOverride
I noticed the battery drain 2 nights back. I leave the phone at usual place right next to the bed. i always get 12-14 hours with moderate use. After the update the battery is done for by morning. Before the update this never happened. Now with use and 3G on, I get like 6-7 hours. many times my phone switched off. The same has happened at my office, a completely different location.
3G signals are amazing at my city. Its everywhere. Anyway, I'll give it a try with my other connection. I dont know if you have noticed but a lot of people who updated the latest firmware are facing this issue.
I am devastated now! Slightly_frowning_Face
CrashOverride
Tried with new sim. Same problem. I think the drain takes place when the phone is on idle. If you are using it now and then, the drain is significantly less.
In short the drain happens only on standby.
CrashOverride
HELLO!!! Anyone from SONY please give me an answer for this problem. This question is not answered... So please stop Assuming it is answered!!!
abhis07
I am also facing the same problem. Extream battery drain after updating to 4.1.B.0.587
After moderate use battery lasts for only 8 hrs. Slightly_frowning_Face
Please provide some solution or a new update to fix battery drain  problem.
CrashOverride
Glad too see some one else how has realised that this problem exists. I dont know why but for some reason Sony is ignoring me!!!
I really hope they help or this would be the last sony phone I am going for!
-A really disappointed customer
