As a new user of Xperia mini pro I'm facing some problems - probably most of them are caused by the fact that PC Companion software (ver. 2.10.079) can't see my phone. In general I'm able to use "Media Go" and "Files manager" (these applications work fine), but PC Companion informs me, that phone is not connected. After plugging in USB cable it starts to search the phone, but fails... After such failed searching I'm getting mesage, that "PC companin shall be updated", but then... I'm getting info, that I already have latest version of PC Companion.
My phone software compilation version is 4.1.A.0.562-v2.
Did anyone of you face similar problems? How to connect properly phone to the PC Companion, such it would see it?
My wife has just bought SE Live with walkman, and mentioned version of PC Companion can see it without any problems...
Another thing is - do you know what could be the reason for delayed automatic screen rotation? I have only few widgets on desktops (clock, frame with a picture and some buttons to on/off data transmission, wi-fi, etc.).
If there were similar subjects created already - please forgive me crating new discussion, but I was not able to find them.
Thanks in advance for help.
Przemek
Originally problem was observed on PC with Windows Vista.
Now I've tried to repeat all on PC with Windows 7 - and still the same issues are occuring.
Any other ideas how to proceed with this issue?
Till now all proposed solutions seem to be guessing than knowing what to do...
can you show the error with the sony update service?
Translated message is more or less: "Phone contains modified software, that can not be updated".
What is strange - both phones (my Xperia Mini Pro and wife's Live with Walkman) are getting the same message, but both are new with original software "as it was installed by manufacturer".
usually that error pops up when your bootloader is unlocked, one solution is to relock the bootloader first before proceeding update.
I assume that description of how to do it, which I found somewhere else (see below) is OK?
Additional question - what about warranty? Does such "flashing" affecting warranty of the phone? If yes - then this is not the solution here...
uliwooly wrote:
1st Backup everything
2nd Backup your current firmware
3rd Follow the steps bellow to flash your phone (remember I'm not responsible if anything happen to your phone and this "might" void your warranty)
4th enjoy
it's useful to have
How to backup Xperias
download FlashTool
http://forum.xda-developers.com/showthread.php?t=920746
or
http://androxyde.github.com/Flashtool/
and the ftf files here
Arc
4.1.B.587
http://forum.xda-developers.com/showthread.php?t=1836071
http://forum.xda-developers.com/showthread.php?t=1330314
Arc S
4.1.B.587
http://forum.xda-developers.com/showthread.php?t=1836311
Neo V
http://forum.xda-developers.com/showthread.php?t=1678690
Ray
4.1.B.0.587
http://forum.xda-developers.com/showpost.php?p=30310466&postcount=61
http://www.mediafire.com/?2o2glqbm6oyf9m9
http://forum.xda-developers.com/showthread.php?t=1679658
Pro
http://forum.xda-developers.com/showthread.php?t=1682185
http://forum.xda-developers.com/showthread.php?p=26767746
Neo
http://forum.xda-developers.com/showthread.php?t=1678993&page=7
Active
http://www.mediafire.com/?i6adxlhk3xsl02b
http://www.mediafire.com/?knu6n2ms257y37m
Mini
http://forum.xda-developers.com/showthread.php?t=1708058
Mini Pro
http://forum.xda-developers.com/showthread.php?t=1693631
Live w/ Walkman
4.1.B.0.587
http://forum.xda-developers.com/showthread.php?t=1837398
Install it and you will see 5 folders
Custom
Drivers
Firmwares
Loaders
X10Flasher_lib
take the firmware to the "Firmwares" folder
click on Falsh
Press Ok
it will ask you to connect your phone on Flashmode (turn off your phone, press the back/Volume button, then connect the USB) press OK
This is an step by step guide
