Dear all,
my Xperia stopped working yesterday, first the touch became more and more insensitive then after restarting it there wasnt anything anymore on the display. the backlight starts but nothing shows up.
I enabled contact sync via google but it seems that only synced the names and the email but no fonenumbers at all...
so now all my numbers 300+ are on my fone that seems to work but has no display that can be used and therefore also no settings that can be set such as USB debugging for a backup of my contact.
Does anyone has an idea how I can access my data? I found an old vcf on my SD card but that didnt really had a lot of numbers in there...
please help me, the fone still is under warranty but if I send it in most certainly my data will get erased...
kind regards
Elias
Have you tried with PCCompanion? I think you can connect your phone to your pc and with pcc backup contacts on a vcf file.
hi,
no strangely even when the phone completly worked the button for backup was allways greyed out...
I just tried it on a PC instead of a MAC but here the Backup section is not even showing up...
So thank you but no help there.
