Xperia Mini Pro Android 2.1 Chinese Input
Hihi,
Mind to ask as i just upgraded to eclair and seem there is no more chinese input for my xperia mini pro.
Thanks alot for the help to all. Have a great day
7 REPLIES 7
Josh
go to Android Market Place, search for "pinyin" or  "Google Pinyin IME". Once you find it install it.
Thanks Josh. You been a great help. Thanks alot for the swift fast reply ^^ . Its always the right choice to stick with SE always . Thanks bro .
Downloading now. Wondering if SE can make android apps download on to pc then sync to hp as sometimes carrier is very slow at download content ^^. Thanks a million again for the help
Exq me , i wan to ask something for my fren , My fren using SonyEricsson Xperia Mini Pro (sk17i ) . juz todays morning, her use that chinese input pinyin , can't tap out the word? why ?? iz solfware?coz she also downlord form the market [ google pinyin ] also can't use ...... i hope can help her!!! thanks very much!!!
gwhispererz
Hi, is your friend using the built-in Chinese keyboard? If it is, launch keyboard, tap the 3rd key from the right, bottom roll and select Chinese PinYin, then try again.
Hi , just tried your suggestion, but unfortunately still the same. In the end is how?
Whatever also need to say thanks for you . I hope can get more information to this problem ! Coz my fren also buy the phone form my working place no enough half years ,,,,,,,,
sushidushi
Have you (or your friend) looked at the tutorial and help functions of the Chinese keyboard?  To do so, press the symbol at the bottom that looks like a book, then Settings, then Tutorial or Help.  At least that is how to get it on the Chinese keyboard on my Arc...
gwhispererz
Does not sound right?! A few things to check ....
Make sure she is using the built-in Chinese keyboard. Long press 'Write message' area, tap Input method>Chinese keyboard.
Make sure she sees 'CN' on 2nd key from the right, bottom roll of the keyboard.
