Xperia M2 Vibrating
TazS
Xperia M2 Vibrating
My Xperia M2 keeps vibrating continuiously after unlocking the phone.
Its a bit of a pain when trying to do anything on the phone while its buzzing.
At first it did it on occasion, but now its doing it each time I unlock the phone!
Any ideas?
2 REPLIES 2
Thommo
Genius
Try performing a system repair using PC Companion as this will often fix issues - This will factory reset your phone and erase all data so best to backup before you begin
Jake-SonyXperia
Hi TazS,
Welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines
If the software repair does not help, then this is likely going to be related to hardware, in such a case I would suggest contacting Sony Mobile Customer Care, this can be done by using my signature below.
Lets hope the software repair helps.
