hello i had bought Xperia M last month and i have an unexpected problem. my phone won't charge with the charger, but only can be charge with the computer. i try the other charger but no use. but when my charger use to charge another phone it's work correctly.
please give help me:smileysad:
Hi @brent_zairon
Should try to replace the battery if you can get one at least to test if with another battery the device charge ok.
If my answer was helpful for you, please thank me with Kudos.
I'm at disposal for any question.
Best Regards,
Hi. I'm from India. After two years' of good serivce, my Sony Xperia M was facing the same problem. I was charging very slowly, sometimes not charging at all. I have brought it to the service centre yesterday. After inspection, the person informed that the charging port has got damaged, and as the charging port is integrated to the mother board, so the whole mother board is to be replaced. It will amount more than half the price I have bought the phone two years back! I wonder how the design can be such that instead of just the damaged port, the whole electronic circuitry has to be replaced. Is there any other option?
Hi there.
I also have the same problem
Ytyed everything but my phone neither the charging light is not lighting
I opened it because i understand a lot things but it just heat the mother board and nothing shows in display or in computer(doesn't recognize as usb).
I checked do it charge the battery => it has charged but it just heat the motherboard and nothing else.
I want to know whats the voltage of the battery to turn it on?
and while it charges why it doesn't show the red indicator at bottom of phone?
anyone know something more please tell me I am low at sony
