I had purchased Xperia M (Single) just 2 months back. It was not used even for a month but,
1, The camera not functioniong displaying the message " Error! Camera not available"
2, Flash not working.
3, Goes in to silent mode automatically in few hours.
4, Battery charge dropping significantly even in switched off condition.
Except these problems, the phone runs smoothely in all the ways.
I was so passionate about SONY products and selected this model after 2 months of research and considering all the good reviews.
I tried Factory reset on phone settings & repair through Sony Companion software but no luck yet.
Looking around for a solution to get away with these problems.:smileycry:
After the factory reset/software repair, did you restore any type of back up or installed any application? You could always try to boot the phone into safe mode to see if you experience the same behaviour from here:
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008
But if the problem(s) persist and you have done this repair without restoring any type of back up, I suggest that you contact nearest service center. You can contact your local support team for further information about how to proceed with this in the best possible way:
