hi, Im having issues with my xperia T
1. the phone get extremely with even the littlest amount of use some times we the phone is on standby in my pocket with nothing running and the battery will drain rapidly.
2. sometimes when the phone is on charge it will show the full charged battery symbol on the screen but the phone is inative and I will have to force shutdown and restart.
3. If I use the phone as a satnav the battery will drain rapidly and the the phone will overheat and shutdown this is when the car charger is plugged in and on charge
Try performing a system repair as this will often fix issues - This will factory reset your phone
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the onscreen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
Should the issue continue then you may need to either return your device to the place of purchase or contact Xperia care and have your device inspected http://www.sonymobile.com/global-en/support/contact-us/
Hi have try the repair my phone a few times with no joy
