Xperia L Charging Problem
pilandok
Hi Good day,
I bought Xperia L 2 weeks ago, i upgraded the system to 4.2 Jelly Bean, my problem is when i charge it to outlet, it takes very long time, 2 hours charging and the battery added only 5%. but when i charge it to USB-to-PC it is charging normal like 2 hours and it is fully charged. i went to back to the store and they changed the charger, when i get home i charged it, the battery starts at 38% and after 1 hour charging it became 36%.. then i charged it again to my laptop and it charged as normal, i even use my wife's charger (Xperia C charger) and it also normal. this time i went to Xperia Service Center but they want me to leave my phone too, which i can't because i need it and i dont have anything to use. and besides i think that the problem is on the charger, or maybe i dont know. is there anyone here having problem same as mine?
Thank you.
2 REPLIES 2
manjuboyz
Hi pilandok
since it is new phone, same thing was happening to my cel too!!, i read in some blogs charging the phone for entire night(yes whole night!!, JUST ONCE), so i did exactly as they stated, when i was about to go for bed, i kept it charged for almost 11 hrs, and from next morning it was all fine Slightly_smiling_Face
 so you can try this, make sure you drain the battery so that it starts charging from scratch, hope it works
let us know
Manjuboyz Slightly_smiling_Face
NOTE:
Rate me(Kudos) If you are happy with my Resolution, Thanks Slightly_smiling_Face
pilandok
Thank you manjuboyz, I will try this tonight. :smileysmileywink:
