xperia j touch screen problem
2691arvind
Hi Sony,
     I bought my Sony Xperia J on Feb 2013. Now am facing touch issues. I couldn't type a text and any application i tap on, it doesn't select it. It also at times does not respond totaly, the phone becomes static. The phone is very slow with its response time is very bad.If i give my mobile in service center for the Touch screen issue and slow response time/ no response, will the service be provided for free?- Please help me.
14 REPLIES 14
Johan
I suggest that you try to run a software reinstall using SUS.
If the problem still remains you should contact your local support team, to have the phone examined and fixed at an repair center.
The repair center will examine the product and check if this is within warranty or not, but as long as you haven't passed the warranty period and personally damaged your phone you should be fine.
Heikowag
New
Hey, i had the same problem with my Xperia J. A recalibration of the touchscreen solved my problem. You can download the software i use here http://forum.xda-developers.com/showthread.php?t=2068082. Your phone does not need to be rooted, so in general it should not harm your device. But no garantee
recallebration
how do i recallebrate my experia j
profile.country.RO.title
_alexdon_
You need to take it into service for that.
alexdon
recallebration
how do i download it i get error from windows
recallebration
people are saying i can download a file but i my screen dont work for me to do it via phone
and computer says error
recallebration
because its a apk file
_alexdon_
Stop spamming,use the edit button.You could try and download sony update service,but that will reinstall your software.
alexdon
recallebration
ive done that to no avail how do i open a akp file
