xperia go jellybean upgrade problem
chaituklk
i cant upgrade my xperia goo!!!
it says that press and hold the volume down key....while connecting usb to phone during upgrade process.....but its not responding as i did the samee sevaral times........plzzzz reply me..trying still 3 hourss.............
14 REPLIES 14
chaituklk
plzz reply........instead of updation it is showing red indicator immediately after green and enterin into charge mode!!!!!!!!!!help me out!
try this
reinstall PCC > restart your PC > disable your firewall and antivirus > turn off your phone > press and hold the volume key down then while still pressing down the key connect the usb cable > do NOT release the key > your PC should start downloading the drivers
you can use SUS instead
Install SUS > restart your PC > run SUS > > turn off your phone > press and hold the volume key down then while still pressing down the key connect the usb cable > do NOT release the key > your PC should start downloading the drivers
Update Service (SUS)
for future reference
chaituklk
thanx @uliwooly
but it didnt work......it is entering into charging mode and no installation of drivers!
restart your PC > press F8 > safe mode > try again, also install the latest JAVA and WindowsMediaPlayer.
chaituklk
and im using windows vista 32 bit
chaituklk
@uliwooly
tried every thing...........but no change..:(:(
can you try with a different PC?
also install JAVA (google JAVA download)
