Xperia GO JB GSM network problem
drevster
I expieriencing GSM problems with my GO.
it happened twice
after the night i notice the battery is drained about 20% (wifi, gps an all other stuff is off). the phone shows gsm network level is full, but i cannot receive calls. after i tried to send sms the network level went to zero. after restarting the phone everything worked just fine.
The first time phone was on 3G mode, second time it was switched to 2G mode.
anyone with same problem?
Alexander1
Maybe there was some problem on the network. I recommend that you try with another SIM card if you have the possibility.
If the problem persists with another SIM card I recommend that you try to repair the phone software using the program PC Companion:
