Xperia E Speed Dial
Xiuyao
Xperia E Speed Dial
My phone is Sony Xperia E (C1505) , I want to know how to set my "Speed Dial" number.
Thanks!!
2 REPLIES 2
Alexander1
Xperia doesn't support speed dial. However you can add a shortcut to a contact to have on the homescreen. Press the menu button when on homescreen > add > shortcuts > contacts > select a contact. If you add more then one contact on the homescreen you can put them in a folder by simply drag and drop one contact on another one.
discretion1
You may try adding a shortcut on home page as described in the previous post, or try adding it to favourites list in 'Phone' menu.
Goto Phone--> Groups --> Favourites--> add a contact to this list.
The first option would directly dial the number when you touch it, while the second one is more like a group of special contacts separated from the main contacts list for quick access.
