xperia C1505 serious problem
Taky
Hi .. I have a Xperia E c1505 was using and started to go slow and force applications to close, then I reset factory was shut down and did not turn the plug in charger does not charge or entering recovery but when I give Flashmode the power button red LED flashes 3 times but nothing more, but nothing different chargers use, buy him a new battery but nothing stays the same, the difference between the batteries is that with the new and not the red LED flashes, it is rare for neither was a fallen or is a wet or anything, it was rooted and the bootloader unlocked but had the Rom factory only took away useless apps bienen factory but nothing else, it worked so long, I hope you can help me, thanks greetings
2 REPLIES 2
@Taky
Sorry to hear that, contact your local Xperia Care
VladHhHhH
have you found the solution? i have got the same problem, but i haven't rooted it
